This old truck started fine for 56 years on 6v. But from what I gathered, the guy that had this truck for a
couple of months this summer, between the original owner and me, decided that the fix for bad grounds,
bad cables and a bad generator and starter was to just up the voltage.
Well now it's going back to the original 6v set up with all the worn out parts and units rebuilt and the
corroded connections fixed. These trucks start just fine when everything is put right.
Denny Graham
Sandwich, IL
