Has any one found or know what to use for the front disc brakes for a 3800 1 Ton with the 3500 lbs Axle. I need to know what discs, calipers, and bits and pieces to make it all work. What vehicle it came off of or # of parts used. Also which power duel master cylunder the floor to use with a 14 inch rear end with brakes. There is no info in all of the forums list I have looked at and 3/4 and 1 ton trucks seem to be over looked. There are lots of info for 1/2 tons. Please help.
