The floor ends up being just about where the little floor filler piece around the handle near the bottom is on the picture of the the hand brake you posted in this thread. The part with the "teeth" on it attaches on the right side of the transmission on a stock set up. There are actually two bolts that attach it to some bosses on the transmission through the two holes on that part which I believe is called a "pawl". You can possibly make a part with threaded holes in it to screw the emergency brake onto and mount that part onto the transmission.
