8 members (Otto Skorzeny, Paul Mullen, Joe H, 55shaker, greenie-reddy, Steveoreno, Bill Hanlon, KEVINSKI),
83
2
Mod | | | Forums66 Topics128,188 Posts1,057,330 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy John53, in theory you can swap parts to turn your torque tube type transmission into an open driveshaft type, using the bigger truck transmission parts. The two transmissions are actually the same inside. As to the more speed, I assume you're going to switch to a higher speed differential gear set, if you're going to play with transmissions anyway, why not install an overdrive transmission of the appropriate size? Lest We Forget. | | |
