3 members (jay d, 2 invisible),
54
3
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69387 12/02/2006 6:59 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Did you cut enough off of the tip of the input shaft ? Looks like you need to extend the splines with a narrow grinding wheel.I even ground down the spline hub surface of the disc.I ground the side that faces the transmission.There is a lot of info on this subject.You might do a search in the hipo section as well.Here's a couple of pictures of mine. splines clutch disc ground side other side not ground on disc 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
