tractorboy,
I haven't done this swap, but remember seeing info posted about it. Everyone seems to mention using a small die grinder to lengthen the splines on the input shaft so the clutch disc can slide further down the shaft. Not doing this could certainly cause the problems you are describing...I think!
Stuart
