Does anyone have a suggestion on how to remove a stuck door hinge bolt? It is the lower bolt on the lower hinge on the passenger door.
Here is everything I have tried.
1) Brute force with a socket wrench and 2 foot cheater bar. 2) Heating the bolt with a torch and applying brute force in #1 above. 3) I could get a WD-40 straw down to the bolt behind the frame post so I sprayed PB blaster on the bolt and applied brute force again.
The results have all been the same...no movement. Any ideas would be appreciated.
Thanks, Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
