| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Some electric pumps have a habit of causing flooding problems, due to high fuel pressure. If you choose to leave it in place, hide it back near the tank outlet out of sight. I've seen people gut out the original engine-mounted pump and run a straight-through pipe to cary the fuel, with the electric pump mounted near the tank outlet. It's a good idea to wire up a relay that triggers from engine oil pressure in series with the pump, so if the engine stalls the pump doesn't fill the crankcase with gasoline. I've seen several cars and trucks with gas dripping out of the tailpipe, or the crankcase vent from a runaway electric fuel pump. Jerry
