Hi and thanks for all the info....you guys are great...I had headaches trying to find information on what to do when starting an engine that had sat...A friend got me on to Stovebolt, and I can see why it is the best....
I have also heard that pouring diesel fuel into the engine, after removing the valve cover is a very good way to free everthing up before hand turning it....
At anyrate, I will take all your advice and put it to good use. I will be pleased as hell if after all this...the ole girl just fires up!
thanks again
paul
