In the four years that I've been back in the loop Pete, I haven't seen any of them that fit the door panels right out of the box.
My solution was to make a 1/8" thick sheet metal form that matched the four radius of the door panel. Then with it mounted up in the vise I used a body hammer to reshape the corners till they fit the door panel. Pretty typical of most of the stuff we get from the vendor, not to much different than Harbor Freight, that is, you have to rework most of it to make it work!
http://www.pbase.com/dennygraham/image/129635160/large
http://www.pbase.com/dennygraham/image/129635164/large
http://www.pbase.com/dennygraham/image/129635168/original
http://www.pbase.com/dennygraham/image/129635169
Denny Graham
Sandich, IL
Denny G
Sandwich, IL
