2 members (Bill Hanlon, 1 invisible),
62
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Troy, In my opinion, by the time you mess aroung trying to install a miss fit tank you will have spent the same amount of money as just getting the correct one from the start. The correct tank will have the filler neck, drain plug and sending unit all where they need to be. Mike B  | | |
