| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I HATED sanding that part!
Use a good, flat paint stick for everything except your final sanding before paint, but the trick is to sand in a diagonal "X" pattern from the top to the bottom of the beltline. That way you'll not leave any flat spots.
For your final sanding before paint I used a semi-hard rubber block with 400 wet. For the parts that curve around a corner you can just use your hand but always work in a diagonal "X" pattern. | | |
