| | | Forums66 Topics128,180 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68426 02/06/2007 1:47 AM | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | The main bearing torque is indeed 65 ft. lbs. However, the rear bearing should be done last. It should be torqued to 10 ft. lbs. and then, tap the end of the crankshaft on the front or toward the rear. Now tap it in the other direction. This is suppose to insure that the upper and lower bearing thrust surfaces are lined up. Finally finish torquing it. | | |
