since i can't "normalize" the engine to adjust valves prior to start-up, if i set the exhaust clearance at .020 and the intake at .013, would that give me enough lash to allow normalization and then reset clearances to factory specs?
still a few days away from actually starting the engine but i am planning on setting the valve clearance in the morning and wanted some input.
