If you have the short bed, the wood is 77" long. Long bed uses 87" & 97" wood.
You must seal all sides to insure against warping and bowing from moisture. Use a marine spar varnish and cover all sides. Any uncovered areas will allow moisture in and cause the wood to warp.
Harold
Is a restoration ever finished?
