I have a ’53 3600 with the original rear end. On the top of the rear axle housing on the driver side, there is a small tube with a loose fitting top that I take to be a breather tube and cap (the cap appears to be simply crimped on to the tube but spins). Recently the rear end seemed to be leaking (never before) so I changed the gear oil in the rear end up to the fill plug on the back of the housing. After some driving, I see that it is dripping a little gear oil again. I wiped the casing with dry paper towels and have determined that it is coming from the “breather cap”. Should this breather have some felt or other suitable packing inside to allow for air to escape and enter but prevent the oil from “blowing out”? There appears to be nothing under the cap as it turns freely and is loose. There is nothing that I can find in the shop manual that mentions this.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
