0 members (),
40
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68201 11/06/2006 8:08 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | There's a nut on the studs that holds down the rocker shaft and the acorn nut only holds the valvecover. Find an old 216 head and take the studs from it. Torque the studs with nuts the same as the other 2 bolts. Use a 216 gasket with the old valve cover.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
