| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...would like to put newer disk brake type axle under front... How do I get a safer more modern setup under the current body and/or frame? One method is to swap the front axle (and rear axle too if you like) http://www.stovebolt.com/techtips/bigbolts/p30swap/Read through that, it's doable, but not simple. Grigg | | |
