| | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | If you had a different sub frame put in, the 2 inches has to be in front. Moving the front axle back 2" may get your tires tangled up with your fenders. If you are measuring correctly, I would move the subframe forward 2". If you don't know how to weld, I would recommend a professional welder. Donnie Riske who is right down from the street from you could fix it right. http://www.riskefleetservices.com/
