| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67847 10/28/2006 10:30 PM | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | After I had my 52 for a couple of months the u-joint went out. After I replaced the u-joint I lubed with 90 weight gear lube via the square plug in the rear of the tranny. A pint is good, a quart is better mentality prevailed. After filling the tranny, I decided to check the rear end, and gear lube poured out. So note to self follow the manual. Ya don't need more than a cup or so to lube u-joimt. Jimmie. | | |
