I meant to bond the two ends of the rubber seal, before I put it around the glass. This is for the rear window seal...on a '51 5 window truck.
My seal came as a long piece that needs to be trim to size and calls for bonding the two end together to form one piece....That's where I am stuck, can't get anything far decent to bond it and once I start installing it around the glass the whole rubber seal comes loose and the ends....Any advice?
