| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you sure about the 3/16? I would suspect 5/16. If you are close to the threads, it might be possible to collapse it. If not, you might want to run a 5/16 bit through it and then tap it to 3/8X16 and drill a 3/8 hole in your bracket. | | |
