4 members (greenie-reddy, pauld, 2 invisible),
85
2
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | Just got done with further diagnosis of the noise. It now does it intermitently going from any gear to the next, not just 1st and reverse. I was able to make it happen with my wife at the controls and me underneath. It definitely is not coming from the trans but more toward the clutch area. It's not a chirping or squealing noise like described for a pilot bushing. It's really loud and will go away when you step on the clutch a little. Now I'm thinking it might have to do with the disc. could there be a spring that's jumping in and out and hitting the flywheel or pressure plate? seems to me that if a spring was broken or askew it would be constant not intermittent. | | |
