| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | LCT, It may be easier and cheaper to have the right side ell brackets and arm made and then buy two matching mirror heads. The mirror head you have now doesn't look original, it look to big. Before going to the trouble of making a right side bracket and arm you might want to confirm the support bracket with the captured nuts is installed inside the door. Take the door panel off to confirm it's there. If it's there you can take a centering punch and put it through the nuts and give the punch a light tap to mark where to drill the holes from the outside. Take care! Mike B  | | |
