| | | Forums66 Topics128,084 Posts1,056,334 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | A 1/2 ton axle will fit your truck fine. You will have to use 1/2" dia. u-bolts rather than the 9/16" u-bolts that are on your 3/4 ton now.
You can also upgrade your stock front brakes by going with a Bendix setup from a '53 to '59 3/4 or one ton truck.
