3 members (Stewart2, 55shaker, 1 invisible),
145
3
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I am not positive on this, but if I am that would be an engine you would want to keep. I believe the engines with the 010 on the last 3 digets means it is a 4 bolt main and also it has a quite a bit better grade of cast iron. If it is an original truck engine it would have the low performance heads. Probably a set of better heads, either the 1.94" intake or better yet the 2.02" and a mild cam would make a vast improvement without spending a whole lot of money. If I am right about the engine being a 4 bolt main with the better block, I would hold onto it. | | |
