2 members (TUTS 59, Ponchogl),
106
2
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66975 10/09/2006 10:29 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I have always started my engines full choke and run them till warm 1/4 to 1/2 choke. A heat riser will cause poor atomization of fuel on a cold run if stuck and will allow the intake to warm faster if working. Now if you live in the snow belt the heat riser is important for short drives.
To me the condition sounds normal, if the choke is pulled all the way out and you try to drive it its gonna buck, snort, and smell like fuel. Try 1/4 way out after start till warm. If it isn't better then worry about heat riser.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
