8 members (1955 1 Series, Steelonsteel, 55shaker, GRNHydra, 51sub, Wally / Montana, Peggy M, Hotrod Lincoln),
81
3
Mod | | | Forums66 Topics128,141 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Engine installed after 1 yr, wiring done to start the eninge. When I crank the starter engine rotates with starting gear but doesnot fire up. I put the inline spark plug tester 1 at a time and saw the light come up in every spark plug. What does that prove, does it prove distributor is functioning and the spark plugs are also good or spark plugs could be a problem also. I have put the gas tank and I have gas coming up to inline filter close to caruberator. I put some gas from the top of carburetor. it wont fire up some time some back fire and some smoke from exhaust manifold. Is this electical problem or carburetor need a rebuild. It was sitting for exactly one year before that it was deinately running.
Need help and inputs.
Thanks Ganesh | | |
