7 members (Shade Baby, SNOYL, Guitplayer, Thom75, DoubleB, UtahYork, 1 invisible),
105
2
Mod | | | Forums66 Topics128,271 Posts1,058,416 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Joker, If you are asking me whether or not to try it, I would say no. Let some of the wiser heads weigh in first. If one sender has the high ohm reading when it is low and the other when it is high, I am not sure how your gauge would read that. Maybe backwards. (Or maybe let all the smoke out.) If one sender was 240 ohms full and zero (or a low reading) empty and the other was 30 ohms full and zero empty, then a resistor in the neighborhood of 33 - 39 ohms (and at least a 5W rating) across the two leads would bring the 240 ohms down to 30ish. But yours is reversed. The principal does not apply.
Pity too, that would have been too easy a fix. The resistor would probably cost about a quarter.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
