You can easily check the accelerator pump by
looking down the carb throat & moveing the
thottle linkage. A stream of gas should squirt
into the carb. If thats not the problem I
would check the fuel pump pressure& volume.
If thats not it I would replace the fuel pump. smile
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
