| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | Thanks so much for the links! A BIG help for sure! Any idea where the braces (ht.from floor) should be placed? Should I put one from side to side, maybe a couple diagonal ones? It seems wise to cross brace the cab as well as side to side and from front to back. I have pictures of the pickup cabs being built and they used a big jig or fixture to hold all in place whele the cab was assembled. Know that I am working on a GMC Panel. It seems to me the floor, step, and pocket is the correct order as you need the floor in place to install the step and the step needs to be in place before the hinge pocket goes in.
1999 GMC Yukon 1957 GMC 100 Panel
