| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66159 09/21/2006 3:47 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | won't be a great ratio for stop and go city driving - the fit is workable tho it's narrow and you have to move/replace the spring perch plates to fit the width of the truck spring mounting - I had one on a TF frame for awhile [57 car actually], found a proper stock one because I didn't want the 5 bolt wheels and the car rear isn't as strong - if the 5 bolt is what you want, go for a newer truck rear w/ slightly lower gears, if you want highway gears look for an original OD 3spd or a later OD 4spd
Bill | | |
