Before going back into the carb, try readjusting the idle for a leaner mixture; with more throttle opening.
If you have a perfect carb (oops, forgot we are talking about a Rochester B
), and the idle is set too "fat", the vehicle will exhibit exactly the conditions you describe.
Jon.
