| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | I have completed 1953 31oo chevy. Have 56 235 in. Starter sometimes clashes with flywheel. I remember these noises back when. My age is now given. The flywheel is damaged. The somewhat blunt end of what I call Bendix teeth is hitting fly/wh. and not carring thru,(engageing_. with stamp starter I should be able to force thru to flywheel before amps are applied via switch on starter with tapered teeth on starter. Do I need to randr starter and file, grind teeth to beter taper on starter. or flip fly/wh the only way
Plattelnjpichler
