Still sorting out engines...
Have three '53 235 blocks... if my research is correct, these still were splash-oiled, poured rod-bearing engines...
Is it possible to rebuild them as full-pressure 235s, and use insert bearings, and if so, what mods are necessary.
Or is it best to just rebuild stock, or not bother with them at all ?
(One block appears to have a '54 head on it... do the the heads swap between the '53 to '55 engines before the water pump moved down to the block ?)
Thanks...
smile
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
