8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Was concerned about the 4 bolts in the center of the cab floor. Reinforced the cab floor with metal plates center lap belt pics The two outside bolts I used the washers that cam with the kit lap belt bolt pic The belts I used are from classic parts. If your a larger diameter fella you may want to look into the longer belt kits. | | |
