8 members (Gdads51, Charles in CA, Wally / Montana, Nick in Manitou, J Lucas, sron48, David1927, 1 invisible),
93
6
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | It was the grounds, you guys nailed it. I ran two ground straps, one on each side, from the bedsides to the frame and that solved everything. Before I put the straps on I did verify the issue by running a small wire on one side only to the frame. Try the lights and such and no go, hook the wire up and it all worked. I can also say that those lights on the back are far brighter than they have ever been. Amazing what proper grounds will do! Thanks for the help!
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
