yep, wasn't expecting that.
had to pull an inspection type plate, then unbolt the tran from the bellhousing. pull the tran, pull the fork , pressure plate, clutch, and flywheel. then four more bolts for the bellhousing.
man all that stuff is heavy duty.....and heavy.
thanks
