0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | assuming it is just in that cylinder- bent valve; then you check for compression on the other cylinders (to make sure that it isnt the cam shaft that got stuck and that the piston hitting the valve didnt throw off the rest of the valves) and if you have compression on the other cylinders your in luck. then you gotta take off the head, have it checked for cracks and make sure the piston isnt tottaly f***ed up. and that is just if the valve is bent. broken is worse. im sure im not the only one that has been through it.
66' Chevy C-30 Rat
Entire Thread
Battery Cable Heats, No Crank Volts
| 59 rolling iron | 05/14/2010 3:55 AM |
Re: Battery Cable Heats, No Crank Volts
| glasman | 05/14/2010 12:47 PM |
| 3B | 05/14/2010 3:58 PM |
| Cletis | 05/14/2010 5:29 PM |
| Hotrod Lincoln | 05/15/2010 2:58 AM |
| 59 rolling iron | 05/15/2010 3:17 AM |
| 3B | 05/15/2010 4:39 AM |
| 59 rolling iron | 05/15/2010 2:24 PM |
| leitmotif | 05/15/2010 11:46 PM |
| retired wrench | 05/16/2010 3:48 AM |
| larry_g | 05/17/2010 11:03 PM |
| 59 rolling iron | 05/19/2010 2:16 AM |
| larry_g | 05/21/2010 9:32 PM |
| BrianToste | 05/26/2010 3:42 AM |
| 59 rolling iron | 05/26/2010 5:08 PM |
| BrianToste | 05/27/2010 4:04 AM |
| 59 rolling iron | 05/27/2010 8:35 PM |
| BrianToste | 05/31/2010 2:31 PM |
| 59 rolling iron | 06/10/2010 4:55 AM | |
