| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | I have heard that you can make a carb spacer out of a hard wood to insulate the carb from the hot intake manifold. I would try a half inch spacer and see what happens. If you are afraid the wood could be a fire hazard (about a thousand to one shot I think) you might try some sheet pcv cut to size. You also might try opening the hood after you stop, to let the heat escape faster. And last I have heard the ethanol mix gas (which runs perfect in my '49 6400) has a slightly lower boiling point. | | |
