| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I have been searching for about 2hrs now and cannot find any info on how to remove the tube. I did see something that said it was a twist, but I tried and it did not budge. Mind you the entire side of the block has oil and gunk all over it. A friend of mine told me to clean the vent tube that the oil leaking by is from there or from the valve cover vents. Did the valve cover vents after I found them and now wanted to do the oil/fill vent tube.
Also he said to pull out the insides and soak it in gas. I probably sound stupid here but is there some place that has the description of pulling out the inners?
Thanks and like I said I am sorry if this was covered. I found multiple listings for rear seals and such just no reference to the vent tube. | | |
