2 members (Southerntruck, Hush),
150
2
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | so you put a different starter in and had the same problem more or less? have you checked resistance of your ground cable; from the negative post to the block? and when you say you heard a grinding sound- was the motor turning over at all, or was it just grinding from the starter to the fly wheel? if it was from the starter to the fly wheel you may want to try and manually turn the motor over to make sure that it is not jammed up.
66' Chevy C-30 Rat
Entire Thread
Battery Cable Heats, No Crank Volts
| 59 rolling iron | 05/14/2010 3:55 AM |
Re: Battery Cable Heats, No Crank Volts
| glasman | 05/14/2010 12:47 PM |
| 3B | 05/14/2010 3:58 PM |
| Cletis | 05/14/2010 5:29 PM |
| Hotrod Lincoln | 05/15/2010 2:58 AM |
| 59 rolling iron | 05/15/2010 3:17 AM |
| 3B | 05/15/2010 4:39 AM |
| 59 rolling iron | 05/15/2010 2:24 PM |
| leitmotif | 05/15/2010 11:46 PM |
| retired wrench | 05/16/2010 3:48 AM |
| larry_g | 05/17/2010 11:03 PM |
| 59 rolling iron | 05/19/2010 2:16 AM |
| larry_g | 05/21/2010 9:32 PM |
| BrianToste | 05/26/2010 3:42 AM |
| 59 rolling iron | 05/26/2010 5:08 PM |
| BrianToste | 05/27/2010 4:04 AM |
| 59 rolling iron | 05/27/2010 8:35 PM |
| BrianToste | 05/31/2010 2:31 PM |
| 59 rolling iron | 06/10/2010 4:55 AM | |
