| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 66 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 66 | I am having a real nightmare with the rear pass one on my '55 1st. it feeds off the brass block and travels on top of the axle and then kinda loops out and threads into the wheel cylinder, I could not get the old one out without unbending it Is there a trick to installing the new one? Do you pipe it in and then try to curve it? I've ruined about four lines and counting... Any hints tips would be grand. Thanks in advance! Pat | | |
