| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | As Ron stated pressure is an issue. The factory GM pump puts out about 1300psi and the Toyota (and Mustang II rack) operate on about 900psi. I have done both and the best way that I have found to regulate the pressure is by adding shims (small washers) to the pump control valve. The kits are available through speed shops or aftermarket suppliers. The last kit I bought was made by Bill's Hot Rod Parts in So Cal. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
