8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna),
154
0
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59 rolling iron, you can't have too many ground wires! Hotrod Lincoln may be right about a locked/shorted starter or a positive cable that is shorted against something. You mentioned poor quality ends, and I was wondering if the cable was becoming disconnected at the end/ends.I would try another cable, and if it's still the same, then pull the starter as Hotrod Lincoln suggested, hope that helps. | | | |
Entire Thread
Battery Cable Heats, No Crank Volts
| 59 rolling iron | 05/14/2010 3:55 AM |
Re: Battery Cable Heats, No Crank Volts
| glasman | 05/14/2010 12:47 PM |
| 3B | 05/14/2010 3:58 PM |
| Cletis | 05/14/2010 5:29 PM |
| Hotrod Lincoln | 05/15/2010 2:58 AM |
| 59 rolling iron | 05/15/2010 3:17 AM |
| 3B | 05/15/2010 4:39 AM |
| 59 rolling iron | 05/15/2010 2:24 PM |
| leitmotif | 05/15/2010 11:46 PM |
| retired wrench | 05/16/2010 3:48 AM |
| larry_g | 05/17/2010 11:03 PM |
| 59 rolling iron | 05/19/2010 2:16 AM |
| larry_g | 05/21/2010 9:32 PM |
| BrianToste | 05/26/2010 3:42 AM |
| 59 rolling iron | 05/26/2010 5:08 PM |
| BrianToste | 05/27/2010 4:04 AM |
| 59 rolling iron | 05/27/2010 8:35 PM |
| BrianToste | 05/31/2010 2:31 PM |
| 59 rolling iron | 06/10/2010 4:55 AM | |
