2 members (Southerntruck, Hush),
150
2
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59 rolling iron, did you reinstall all your ground wires after your head installation? The fuel system should prime itself as soon as you turn on the key. You may have a problem with your positive cable, try replacing it with a known good one, good luck. | | | |
Entire Thread
Battery Cable Heats, No Crank Volts
| 59 rolling iron | 05/14/2010 3:55 AM |
Re: Battery Cable Heats, No Crank Volts
| glasman | 05/14/2010 12:47 PM |
| 3B | 05/14/2010 3:58 PM |
| Cletis | 05/14/2010 5:29 PM |
| Hotrod Lincoln | 05/15/2010 2:58 AM |
| 59 rolling iron | 05/15/2010 3:17 AM |
| 3B | 05/15/2010 4:39 AM |
| 59 rolling iron | 05/15/2010 2:24 PM |
| leitmotif | 05/15/2010 11:46 PM |
| retired wrench | 05/16/2010 3:48 AM |
| larry_g | 05/17/2010 11:03 PM |
| 59 rolling iron | 05/19/2010 2:16 AM |
| larry_g | 05/21/2010 9:32 PM |
| BrianToste | 05/26/2010 3:42 AM |
| 59 rolling iron | 05/26/2010 5:08 PM |
| BrianToste | 05/27/2010 4:04 AM |
| 59 rolling iron | 05/27/2010 8:35 PM |
| BrianToste | 05/31/2010 2:31 PM |
| 59 rolling iron | 06/10/2010 4:55 AM | |
