9 members (3B, Bill Hanlon, JW51, 57 Drifter, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
64
3
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Hi folks,
I have a question for all.My Loadmaster 2 ton has Hydrovac brakes.The things simply will not work without a total replace or rebuild.Can I remove the Hydrovac and just go with regular brakes(new master cylinder,lines etc...)I know I will have a decrease in brake capacity but I will not be pulling excessive loads.Also the two speed axle is not working.Can I swap out the old axle with a late model with electric two speed? Thanks for any and all responses.
Old bolts are the best bolts!
Thanks, JMH | | |
