| | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64336 08/18/2006 2:17 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | They make 2 different front rubbers for the oil pan to the front cover.If they have installed the thin rubber when she needs the thick you will have a major leak .Easy way to diagnosis is leave some of the oil residue on the cover pan area and coat with some baby powder and fire it up and watch for the leak.They also make some stuff called leak trace and it comes in a aresol can you can do the same thing with.Good luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
