| | | Forums66 Topics128,127 Posts1,056,681 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64320 08/12/2006 7:26 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The original tire on an Advance-Design 15" rim/wheel is a little larger diameter than the original tire on a 16" rim.
Also, you can find 15" and 16" light truck radial tires that are up to 3" larger diameter than the original bias-ply tires (31.5" compared to about 28.5") .
My 16" rims were 4.5" wide and the 15" rims were 5" wide. Radial tires for 5.5" rims were easily mounted on both sets of rims. I checked different vendors' on-line specifications for LT (light truck) radial tire rim-width before I went to a local supplier (Cooper) to buy and mount the tires (I used an inner tube and valve protector). | | |
