1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The original V-8 frame mounts are not in the same location as the 235 they are an add-on to the frame cross member. There is a bracket which protrudes below the timing cover on the 235 engine. Earlier trucks & cars had a mount on that very point. You could use something like a rear trans mount from a 350/400TH or something similar. They are about 1 1/2" high and about 3 1/2" long. You would have to drill holes in the crossmember and probably the bracket on the engine. There are also aftermarket crossmember mounts available for V-8 conversions which utilize the center mounts. However, I'm not sure If it would work for the 235 center mount. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
